- WA state
I know that with a 242 t-case that the toe is supposed to be zero.. I would maybe go with that and see how it works?
I am going to be able to pull the jeep up on the alignment rack on wednesday.
Pulled off the freeway today while going to work and hit a bump and got death wobble again. Idk what is going on. I'll be setting the toe at 0 Wednesday and if that (or inward toe) doesn't solve it, then I have no idea what I'll do.
Do you have a drop pitman arm. if your using the stock one itll cause dw really easy.
