_MURDERED OUT_
- Hernando, MS
How do you get that plate perfectly flat and centered inside the rim? Wouldn't that cause some serious wobble and imbalance if it were off even a little bit...
Do you think the weld from the 2x4 to the plate will be strong enough? Even with the reinforcements you described, I can picture it flexing a lot which might lead to fatigue. The firewall isn't all that rigid.
Are you planning to drive this on the road?
The wheel centers are 12.65" OD which is the exact size of a 15" rim on the inside where the wheel center is welded. So i cut an inch from the wheel center lip all the way around and let the new center rest on the old center then welded it in. So the new centers are as close as i can get to being as true as the originals. Steel wheels are always off a hair. And i havent balanced a set of tires on this thing since i bought it in 2002, we dont worry about that crap, with tires 38" or bigger you just ride them as they are. It actually does very well or did may i say, ive had this thing doin 80 on the highway but the front end shakes...
I will be gusseting the mount then tube will connect it to other stuff later. It will definately be a major stress point since all the weight of the front end is on it. But hey, i'm not worried.
And yes i will drive this thing on the road, but just short trips around town and stuff like that.
