Frame Crack? and options
DP two part primer is very good.
avoid thick undercoats which can lift and hence trap wayer, and conceal rust growth under the undercoatings thick textured surface.
Ok! All the parts are installed and my baby is back! Had to weld on the rock sliders after adding the frame stiffeners... and build a new sway bar bracket/spacer to make space for the BEEFY Boostwerks 'ultimate steering brace'. Everything was then etched/painted with 2 coats of Por-15 (1 can goes a long way!).
Thank you all for your help throughout. Will take a couple of pictures once it stops raining here in pdx... hahah... it won't stop
