Bigwoody bringing out more opinions in me.
If you going to go the aftermarket knuckle route why bother with buying a Ford 60 to cut up. Most people are paying about $1k for a Ford 60 then only using the center section and tubes. Might as well get a Rock Crusher or Tera center section which are running around 600-800 and have it tubed. You don't end up with that much more money involved.
Also for those thinking of this it will probably be easier to start with on of the 3" tube 44's (cast mount Fords) and have the thing tubed. Then the seal size can be cut to fit. Guess why Lockwood couldn't talk me out of that housing. Thoughts are thick and money grows on trees. You want to play hard it isn't going to be cheap.
Alright who's called on this:
http://www.sunrayengineering.com/1550.html
No CTM's needed and I don't think you will break them with 35's.
