Was thinking about leaf options and decided if I'm going to pay anything to get this done, it should be an upgrade. As I mentioned, my leafs are old, beat, and bastardized.
Stuff I'd like to "upgrade".
1. Rear up travel. It ... does make it to full stuff, but only barely, with the opposite end of the truck flexed the other direction. Makes the Jeep rather tippy when the rear doesn't want to articulate. Would like to get smoother and lighter up travel and make use of bump stops ... ever. I don't think I've ever come close to hitting mine. I've already got the shocks (through floor) setup for another 3" up and 2" down.
2. Ride quality. It sucks. Rear end rides super harsh due to the 6 leaf bastard pack and that shackle relocation doesn't help. Would like to smooth things out a bit.
3. Rear steer. Shackle being mounted so much lower than the front eye causes horrible rear steer both on road and on the trail. Need to get the leaf eyes at the same height. Only reason I did the shackle drop is to lift the rear to match the front.
4. Axle wrap. All the extra weight from plating, bumpers, full size spare, gear, plating and reinforcement, combined with the weak and raked back leafs, combined with the 35" shoes/4.56 gears/300hp, causes my Jeep to eat u-joints and rear drive shafts all day.
5. I don't like the shackle sitting as low as it does. Gets hung up on rocks.
6. Move the axle back 2".
So I was looking at leaf options, and leaf + ladder bar options, and it occurred to me that I might as well get some longer leafs (better ride and articulation), with the correct spring rate (so I can throw out the shackle drop), and more torsional stiffness (to combat the wrap). My buddies k1500 we lifted recently, weighs a bit over a tonne more than the XJ, but the rear leafs aren't really dealing with any more weight than my Jeep's got at this point (maybe another 500-600lbs over my Jeep). His leafs are 63" eye to eye, 200lb/in spring rate, and 10" high, in a 5 leaf pack.
I figure the ass end of my Jeep probably weighs around 1600-1800lbs.
Take one leaf out of that 63" pack, for an effective spring rate of around 160lbs/in. Both leafs combined would have an effective spring rate of 320lbs/in. They height from the stock leaf mount to the top of the axle is around 5 inches, so I'd need to weigh those leafs down by 5 inches (their arc is 10") to maintain my ride height. 1600lbs would push those leafs down by 5 inches perfectly. 1800lbs might need the one leaf removed and replaced with an XJ leaf perhaps.
The 63" leaf is not offset, so that gives me 31.5" center. Just measuring around my Jeep, I found that if I measure from between my bumper and the body (pictured below), I've got 33.5". If I mounted the rear spring eye right between the bumper and body, that'd locate my axle 2" back from where it sits now (just enough room to clear the fuel tank), and then I'd just need to fab up a new front spring mount. This would pretty much answer all my above issues. Shackle would be sitting several inches higher than it is now without losing any lift, the longer leafs should flex better, but as the spring rate is higher and they're built for a bigger truck, they shouldn't wrap nearly as bad as I'm getting now. Leafs would sit level which deals with all the suspension oddities.
So, the million dollar question... Who thinks a set of 63"x10" arc, 200lbs/in leafs (minus one leaf) will do the job I'm hoping for? The math says they should give me the ride height I want, I know on my buddies truck, they ride much smoother than mine and he's got substantially less axle wrap than I have, and he's got 37" shoes and a tonne of extra mass to move. He also seems to flex out pretty well (better than me for sure).
I COULD just rip them off his truck at some point to give'm a try, but damn that's a lot of work that I'd just have to put them back on his truck by the end of the day
. Anyone else running 63" chev springs or have good input on leafs?
