blistovmhz
- Vancouver, BC
Right on man. One piece of advice. See if you can fit the np241c under there. Can grab one for $100 (or free), bolts right on, is substantially stronger than the np231j, and will save you money on adapters. I don't know why no one does this. Maybe because the SYE's are sometimes hard to get ahold of (I think JBConversions is the only game in town, and they can be flaky about stocking anything). But, if you can get the SYE for it, it's only $300 vs the $700 for the GM/Jeep adapter.
I'm just starting another build right now. 85 4runner, another 5.3/4l60e, probably the 241c for now unless an Atlas shows up, Land Cruiser BJ60 front axle and LC BJ60 rear with Toyota mini tubes and outers (for center).
My plan this time is to just use the entire GM PDC. This way there's almost no wiring to be done. Just give the PDC power, connect the brake switch to the PDC, and plug it all in and done. Gives you a ton of extra fuses and relays for auxiliary stuff and saves me a day of wiring.
Oh, also... Depending on your lift (or oil pan choice), you might wanna just do the motor mounts yourself. Novaks mounts put the engine unfortunately high up. Do some measuring, but I think the motor could be 2" lower than Novak puts it. Lower COG/RC and you could probably clear the stock hood.
