BrettM
- michifornia
$2900 for a 60/9" minus the third member. http://www.pirate4x4.com/forum/showthread.php?t=447235
BrettM said:$2900 for a 60/9" minus the third member. http://www.pirate4x4.com/forum/showthread.php?t=447235
Mike L said:Good find. Now if someone her has the dough for it...................... :wave:
-Mike
HOLY COW are you kidding, we ALL ARE!! heck just look at my sig, i made it all and still going, the welder is on over load, i CANT BUY ANYTHING, I HAVE TO MAKE EVERY THING. what is this thing you call money? i have heard of the stuff but i have not seen any since i got MARRIED :laugh3: :laugh3: people still use that stuff?Ghost said:Wow you mean I'm not the only one here trying to figure out how the hell to pay for all this shiat!
Lincoln said:I think the 8" case that currie is using for their hi pinion can't be had in the larger bearing required to run 35 splines. Don't hold me to that it came up when I was shopping quite a while ago. At the time I passed on that axle because I didn't feel it was worth the money and not get 35 spline shafts.
Paul S said:Unfortunately, I've got the small bearing case, so I'll be calling True Hi9 sometime soon.
Paul
Have you priced that thing yet? :wow:Paul S said:Unfortunately, I've got the small bearing case, so I'll be calling True Hi9 sometime soon.
Paul
cracker said:
cracker said:...
(aluminum case add $100)
Paul S said:Currie definitely has small bearing (31 spline) & large bearing (can be used with 31 or 35 spline) HP cases. Unfortunately, I've got the small bearing case, so I'll be calling True Hi9 sometime soon.
Paul
Captain Ron said:![]()
Doh!
Looks like I better get a few more on the way.
--ron
Goatman said:How many of those do you need?
I thought I saw a D44 for the front......?
Captain Ron said:I will be cutting the casting into sections for a proto die.
Cut? Please explain.....Captain Ron said:Seriously, those units are for temporary use, and then sadly, for one of them at least, I will be cutting the casting into sections for a proto die.
--ron
