O.K., went out and bought a Rough Country 3" lift system. Went to put it on this weekend and couldn't get the taller coils in. I disconected the sway bar but couldn't get the axle low enough. Rented a coil spring compressor from Checker but the only one they had wasn't designed for these kind of coils (it was for a coil set up that had access to the inside of the coil from the top of the mount). I noticed the upper control arms restricted the axle from dropping by binding the lower control arms into the mount, so I tried disconecting the upper arms. I got one off but the other won't budge. I gave up and tried putting it back together but now I can't get the upper control arm to line back up. Any suggestions before I pay someone to install this? Also, I twisted off one of the sway bar end links and need to know what are the cheapest quick disconnects out there?
