GraniteCow
- USA
I'm in the process of putting together a Wagoneer Dana 44 for the front of my XJ and was about to order a flat top knuckle kit for crossover/high steer, but just looked under my XJ and realized I might run into clearance issues with the coil springs and sway bar end links. Does anyone know how to set up high steer on an XJ without hitting the coils or ditching the sway bar? Is this doable? Maybe just crossover but not high steer? Is there even any advantage to just crossover but no high steer? Is high steer but no crossover (keeping an inverted y) an option? The flat top kit I'm eyeing is the $700 eBay kit and comes with arms. I already have a Barnes truss/swap kit for the Waggy 44.
Are high steer and crossover the way to go with this, or should I try to build an inverted y setup with the stock Waggy knuckles? Does anyone run a high steer inverted y link? I was pretty excited to go with both high steer and crossover steering, but I drive this thing on pavement and kinda need the sway bar.
