- Columbus, In
I'm not planning on either. Money is too tight! :roll:
Well that weekend is out for me, I have to go to Wakarusa for a wedding (at least this time I'm not the best man) and I have the GF back now so she and I are spending the weekend there at some cheap motel (gulp....hope that doesn't lead to wedding bells for me...). If someone from this area is going down that way you could borrow my hoist and engine stand. I should be done with them by Friday. My hoist will handle the height and weight of the ole 4.0 complete and I have a leveler as well which helps in the install process to get things lined up. Or you could come pick it up, it comes apart easily.
JS
i still havent gotten ahold of the guy yet. so im still not sure yet. i think im gonna grab a cheapie engine stand to do some work on the engine with. a friend of mine is gonna use the stand afterwards. or i could just make it astand and we can pass it around the group for whoever needs to use it.
do i need a I-6 specific stand?
The I-6 is a heavy engine, I'd suggest something with more than a single front wheel, a four wheel is easier to move around, the singles can tip easier.
JS
is anyone going to the CF badlands run this weekend that would let me borrow their engine hoist? i dont have one and im having trouble getting the motor up to get mounted on the engine stands. any ideas guys?
I've been debating between this weekend's Badlands trip or the one next weekend. What's the turnout looking like for this weekend?
Even if I don't bring the XJ out, I live close enough to Attica (~30minutes) that I could load up my hoist and run it out to you. When are you planning on being there?
nice ill be there for sure. bringing along extra coolant ha
a friend of mine let me borrow his engine hoist. so i have that for as long as i need
does anyone know if its easier to put in the exhaust header before i put in the motor?
dammit man! You need to put some padding under that thing. Were they grade 8 bolts?well some not so good news today. first off i had the engine mounted on the engine stand and i went to spin it around to work on the oil pump and the bolts ON the engine stand (not attached to the motor) snapped right off. luckily no damage to the motor. THEN secondly after i got the motor back up right i went to work on the valve cover and mounting that, i was tightening the bolt on the front pass. corner and the valve cover cracked (hairline crack) so im hoping that they will send me a new one.
the bolts that failed werent grade 8 bolts. probably grade 5. i think im gonna replace all the bolts with grade 8 and try it again. with padding!
