Camping350
- In the OC-CA
Got mine on thanks hd first run on New Year's Day.
![image_zps64426324.jpg](/proxy.php?image=http%3A%2F%2Fi1306.photobucket.com%2Falbums%2Fs567%2Fcamping350%2F2001%2520Jeep%2520Cherokee%2520XJ%2Fimage_zps64426324.jpg&hash=36151f9ce75be0127b8916034d7e54c3)
You should try one or two holes forward.
yes you can. The newer design uses a slotted hole in the stock shackle box so you can adjust it down to fit over skids or trailer hitch mounts. If you do so is your choice.
You can see the slotted holes in this photo:
I would use a shim so the hole farthest forward woill be even all the way back.
