BRIANHO13
<- Yum Chocolate
- Spring, TX
Do you have a pay pal ?
Yes, PM sent.
Any way the bolts could be made 10mm longer or so? The two per side that hold the shackle brackets are not long enough for proper thread engagement.
And for those of you who do this on the ground and by yourself here's a little brainstorm I came up with to push and hold the shackle out while installing the brackets. I used an OEM bottle jack. Place it on the leaf pack and jack against the framerail. Do it slowly so it doesn't slip off and spring back on you while you're down there working.
hope your shackles dont invert on you
