Ryan93
- San Clemente
I agree, does Lee feel like mass producing em?![]()
seriously haha
X2 on the Beef! Looks corn fed!
(I don't think we paid for the product placement, so THANK YOU!)
I thought fo sho you were gonna go with a long arm setup.. Are you trying to keep it low budge or are adj's with DBs the new long arm?
I haven't finished mine yet, but I'll be bolting the plates in, sandwiching the body between them and then stitch welding to the floor. Eventually I'll probably run support tubes from the bottom plate to the frame rail somewhere.Hey Jim I just picked the T&G cage up too. Did you weld the plates in or blot em? If welded did you plate the underside of the body? I hear that's what most people do because its so easy the weld thru the sheet metal.
All little trick for prepping washers, nuts, etc for tig welding is to dip them in muratic acid, and then rinse them with water. Works really well on the zinc plated "gold" looking stuff and only takes about a minute of your time to do. You can get the acid at the hardware store.
Looks awesome! Everything takes longer than expected, and if you don't give it the time, you'll never be happy with the end result.
Keep slavin' away....
WOW!!
I use EZ-Off oven cleaner for anodizing, works great!The acid works on anodizing too, eats it right off. Just don't leave the part in there too long the acid will eat the aluminum too![]()
