XJensen
- Sacramento
Sounds like a plan. Like Clyde said push the lower forwardbolt to the back of the lower axle side slot. Or if the slot is on the frame side push it forward
Drop brackets are on the frame side so it needs to go forward towards the axle, I'll see if I can get shims at the parts store, or if any of you long arm guys have them lying around. I'm getting good with a ratchet strap and making the axle go where I want it.Sounds like a plan. Like Clyde said push the lower forwardbolt to the back of the lower axle side slot. Or if the slot is on the frame side push it forward
I know the tie rods are probably shot, I have replacements ready to go. But, how could drop brackets affect toe if I had none of these symptoms before the install? I never touched any of the steering components other than lengthening the drag link.
EDIT: I stand corrected, just took a tape measure to the front wheels, measured from my first straight tire groove to the matching groove on the other side.
Front is 56-1/4" rear 58-1/8" so the front is in by 2 inch's, so I'm toed in.
I've got command Trac tcase with full time 4wd, I looked up the toe it should be 0.That probably just part of the problem. Set you toe to an 1/8" inch, check you caster and post up a pick of your steering.
