at05gt
- Sacramento, Ca
I'm gonna try redrilling the UCA's tonight, inch back should be ok and give me at least a few degrees of caster.
You probably dont want to hear this now but thats rough country for you. Lowest bidder often bites you.
Amost all of us have run rough country in the beginning stages or when trying to cheap out of something. Its all dogshit garbage parts. Bracketry is hard to cheap out on so maybe ypur drops will be ok for a while .
I'll probably be looking into IRO or something similar when I do arms, I can drive it as is without issue so I may just leave it for now until I can afford the proper arms.their joints are all junk, bushings are usually junk too, and overall quality is usually sub par, but some of their parts can get you around for a while.
dont use their control arm if possible, their flex joints are total crap garbage.
Pay the registration, you will have a couple of months leeway to get the smog done (they wont send you the sticker until the smog is done).Ya it comes down to cost vs. time, I have to smog by May 8th or get an extension. Not sure it will pass smog with that big of a crack. I could try to seal it with an Oxy torch and a mild steel filler, I've done it on mufflers and exhaust pipes before. I'm gonna have to take it off the jeep and look at it.
Haha, guess I should read it next time........I already paid the fee's, I mentioned that in the first post.![]()
