North Atlantic Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums. |
Thread Tools | Rate Thread | Display Modes |
Project AllOut: a moderate 2door build (pics warning)
well ive finally bitten the bullet and decided to acquire and build an xj of my dreams. i was torn between keeping my other xj (2" BB on 32s) as a beater and most likely buying a 04-05 STI and putting my xj endeavors on hold. but instead i found a nice 2 door with the goodies and have some big plans
heres the day i brought her home. 97 4.0 AW4 231 with 90K all stock ![]() ![]() my first problem was a leaky windshield so i got to the bottom of that ![]() ![]() some nice rust and such. it turned out there were some decent sized holes eaten through too. a little JB took care of that ![]() used an angle grinder and wire wheel to clean it up and gave it a nice coat of paint ![]() ![]()
SOLD ![]() Current: '96 XJ stock, '17 Ford RS, '17 4Runner TRD |
#2
Re: Project AllOut: a moderate 2door build (pics warning)
had a new windshield installed (my buddy accidently gave the original one a nice big ol crack as we were taking it out
![]() ![]() ![]() ![]() pulled out that washer bottle. i plan to relocate a later year bottle under the hood ![]() ![]() ![]() eh i used a cutoff wheel for the whole thing...a little sloppier than i wanted, not my best work although this is the third rig ive done this on. took the trusty dremel and a grindwheel to clean up the edges ![]() items for rust prevention ![]() im going to put Protekto molding on the edges so i just brushed on some layers of primer and gloss. sprayed it into a cup first ![]() ![]()
#3
pick up an xj D44 with a full detriot from a guy who runs a gear/axle shop. had him swap in 4.88s for me cause it was most cost effective this way. (plus i have no gear/axle experience)
![]() the drums that are on it are kind of beat up so im debating on whether or not to just swap in discs. i really need to do some more research on that first though as i dont want to just shell out bills for the teraflex kit
#4
oi, the fisheye lense is giving me vertigo.. Jeep looks good though.
#5
So what are your longterm/overall plans for it? Looks like you've got a nice starting point.
For the disc setup on the rear 44, just get Explorer backing plates/calipers and 2 driver side (I believe DS, might be PS but I can't remember for sure) soft lines. Use ZJ rotors, same hat height etc, but the center hold is larger than the explorer rotors and they fit on no problem. For the backing plates, it's pretty self explanatory once you hold them up to the mounting flange on the axle. Just gotta open up the mounting holes a bit on the backing plates. You'll need the spacer between the seal/retaining plate on the shafts, and those spacers can be ordered direct from Teraflex. HTH ![]() |
#6
![]() thanks for the pointers on the discs. ive been trying to soak up as much info as i can from the multiple disc swap threads.
SOLD ![]() Current: '96 XJ stock, '17 Ford RS, '17 4Runner TRD Last edited by snail; April 22nd, 2010 at 21:48. |
#7
what do you guys think about these stress cracks near the front bumper mounts? should i definately have them welded up since ill be throwing on a winch bumper? i dont have access to a welder nor the skill
#8
you sure they are cracks in the metal and not just cracks in the paint from the rust?
I'd hit it with an angle grinder and get it down to fresh bare metal and see if the cracks are still there. |
#9
First, remove the fish eye lens from your camera.
I agree with Veeb0rg, use a wire wheel and get all the paint off of that spot. It does look like it is just the paint cracking, as that is not normal locations for the unibody to crack. |
#10
X3 on the wire wheel, clean that up and see if it's actually cracking. You probably want to grind/cut that cancer off anyways, and if you do stiffeners cleaning up the metal will be the first step.
My yard looks like Sanford & Sons. Current crapcan fleet: LS swapped bobbed 79 J10 Honcho, 4x4 auto 4.0 8.25 swapped metric ton 88 MJ CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable. |
#11
as i said before, the fisheye is built into that camera so i would remove it if i could. yup that was just a typo, i meant earlier year washer bottle ill be sure to double-check the cracks, thanks everyone
#12
Any info on the spyder?
#13
it belongs to a girl i go to school with. all i know is that its manual trans, soft top convertible that sometimes leaks in the rain, and has a nice exhaust leak right before the muffler lol. very fun to drive though
#14
Definitely a nice find for the build! There have been times I wish I had started with a two door.
About "the cracking" though. Maybe it's just the fish eye playing games with me, but has it been in a front end collision? If it's not bubbling paint from rust, then it looks to me like that whole area has been "adjusted" with a BFH to get it back to their idea of flat to remount a stock bumper. As has been said, time with a wire wheel will help to figure that out. |
#15
I chipped away some of the paint with a screwdriver and so far it just looks like paint/rust cracking and flaking. I didnt realize the factory caked it on so thick! it was about 1.5mm thick in some of the spots, thats why i jumped to thinking it was cracked metal.
ill still take a wire wheel to it once this rain clears up. anyone know if the JCR front bumper and frame tie-in requires the removal of that sorry excuse of a 'support bracket' (that one thats visible in the last two pics of the 'cracks') it doesnt appear to have been in an accident, everything seemed straight. will find out for sure though once the rust is cleaned up in that area
SOLD ![]() Current: '96 XJ stock, '17 Ford RS, '17 4Runner TRD Last edited by snail; April 26th, 2010 at 15:09. |
Thread Tools | |
Display Modes | Rate This Thread |
Rig/Trail Build level.... Moderate | Ghost | Cherokee Crawl 2010 | 21 | June 21st, 2010 09:02 |
92 2door 4.0/5speed 4x4 Semi project | rubiconrescue | SEC For Sale / Wanted Forum | 1 | January 17th, 2010 14:14 |
FREE 2Door Project Starter | GordoSmasho | Sierra Chapter For Sale | 3 | August 16th, 2009 17:05 |
Opinions on moderate XJ build-up | Googenheimer | Intermountain Chapter | 5 | September 25th, 2004 05:30 |
Vet my build-up plans (warning - long) | Root Moose | Modified Tech Discussion | 9 | August 4th, 2003 07:31 |
