Root Moose
- ON, Canada
Good Day!
I've been away from modifying XJs for about ten years. I have a moderately built XJ (32s, long arms, armour, etc.) that has been completed and used for the last ten years and I have a couple of stock XJs and an MJ project that needs some love.
One of my XJs (2001 Classic) has been sitting for the last ten years and I am going to put it back on the road this winter. For this build I was going to do a mild "OEM+" build. The idea being to use as many factory parts as possible to make a very usable, comfortable XJ on 29-30-31" tires (whatever works and is reasonable). No body/chassis cutting or welding ideally. These Jeeps are starting to get collectible so I want to retain the option to put it back to stock (rust free Jeep).
I could have sworn there used to be a sticky in forums that talked about how to use ZJ springs, WJ arms, and other bits and bobs to do this kind of a mild lift. Maybe my searching is not very good anymore.
I'm also interested in any related/workable steering or braking fixes that can be done. I have WJ brakes on my other XJ and I love them for their stopping power but I'm not a fan of the fiddling required when changing the rotors. I also really like the WJ steering but will that work with a lower lift? Maybe there are better options nowadays. The Jeep will be used for towing up to the rated limit.
Can anyone provide any pointers or links to get me up to speed?
Thanks, All!
Thanks, All!
