RyanM said:This thread went from good info to crap!
JNickel101 said:Wow, anyone tried that ZDDP Plus stuff on Ebay? Looks pretty concentrated....
Or is it just snake oil? I guess you'd have to check your UOA after using it huh?
gradon said:The Mobil 1 hi/mi has 1000ppm ZDDP so it's a lil shy of the recommended 1100-1300ppm for our flat tappets. However, I'm sure even when yall were using various SL rated dinos, that some had levels equal or lower than 1000ppm.
RyanM said::read:
http://www.naxja.org/forum/showthread.php?t=934354&highlight=mobil+high+mileage
I'm running rotella syn 5 40 in the blue gallon jug at walley 16 bucks!!!
wolfmanxj said:Where the hell do you find the rating your talking about? I'm looking at a bottle of M-1 high mileage full synth. The only thing I see is the stuff on the back, ACEA A3/B3, A3/B4-04, API SL/CF. Is this it?
tkjeeper said:I'm now confused. We have different oils up here, can't find Delvac, our Walmarts dont carry rotella, only found 0W50 at Canadian Tire. Was going with Mobil 1 high mileage but don't want to go below 1100 ppm zddp's. I just want to pick an oil and stick with it. Preferably not having to go to 10 bucks a quart amsoil. Thanks
RyanM said:I wouldn't sweat it too bad. Think about the people that are pouring in SM yellow penzzoil 400ppm Zinc :scared:
Yes -That sounds about right for the CI-4/SL Formulation :lecture: (My advanced had about 5 bottles left )88 Wagonman said:Does anybody have the ZDDP specs for Chevron DELO? I have heard it has 1400 ppm but not from a reliable source.
