Wheel bearing noise
Razo87
Hi everyone hopefully I could get some help with this noise I have in the jeep. It’s a 2001 sport 4x4 with 150k miles. I bought knowing the noise in the back, to me it sounds like wheel bearings.
From a stop to roll I hear the sound inside coming from under back seat. I also try with windows down I don’t hear it outside. So I go ahead and replace the rear wheel bearings and seals thats at brake drum. Test drove but noise comes back at higher speeds. Maybe 15-20mph same sound like a wheel bearing, it gets louder as I get faster but I can tune it out with radio. Currently using Valvolines 75-90 full synthetic.
Now that I have free time to dig in since my kids have break from summer school.
My tires that came with the jeep are only 4yrs old and tires appear good. I removed the diff cover and no shavings although I have replaced gear oil not that long ago from servicing the wheel bearings. Maybe less than 100 miles. I disconnected the driveshaft and I turn the pinion I don’t feel like a buckle or binding when turning the pinion. I am playing with the pinion where it bolts to the ujoint and driveshaft. Turning clockwise and counter I have the backlash sound, but if I push inward or pull I have no play, if I push it to the sides the same no play. Wanting to know if there’s another way to test the bearings? My backlash tool just bought the tool shows 0-5 play within its spec. Any more thoughts would be greatly appreciated thank you
You could remove the rear driveshaft. Then run in 4wd. If the noise is gone, then you'd need to replace the u-joints.
Don't forget to lube the output shaft splines at the same time to eliminate another item on the list, but it really sounds like a pinion bearing. What axle do you have?
Even though you didn’t feel play when pushing or pulling the pinion, the noise could still be coming from a worn pinion bearing. These bearings can wear out and cause a whining noise that changes with speed, similar to what you described. These could also be a source of noise. To check, you can remove the differential carrier and inspect the bearings and races for signs of wear, pitting, or damage.
Even though you didn’t feel play when pushing or pulling the pinion, the noise could still be coming from a worn pinion precision bearing. These bearings can wear out and cause a whining noise that changes with speed, similar to what you described. These could also be a source of noise. To check, you can remove the differential carrier and inspect the bearings and races for signs of wear, pitting, or damage.
This makes sense since a worn pinion bearing can produce a whining noise that varies with speed, which matches the symptoms described. A detailed inspection by removing the differential carrier and checking the bearings and races for any wear or damage would be a good next step to confirm if this is the cause of the noise.
