I know the lowers came out to 21.25" but I cant remember the upper. The axle seperation is 8.5" right now and the frameside is like 5" I think. I will measure everything tomorrow.
Yes. And because all the fuel, ect. lines run down the drivers side. And i would have to build a truss over the diff. for the mount. The passenger side is just simpler.
Is that a spacer in those pictures? Why would you do that and not just get the correct rod ends and/or build the mounts to the right width?
Unless I'm missing something and they are temporary?
I welded a piece from the innermost side of the UCA mount to the frame to help with movement side to side. I feel better about it now. I also went to test it out a little. I need a little bit longer of shocks but other then that it is great. When trying to pull the front end up something, the tire just climbs instead of wanting to push back then climb. I love it.
