yossarian19
- Grass Valley, CA
Re: 3.5l engine swap feasability
I hear you and I did read your post.
I'm just not convinced it will be appreciably easier to put a Chryco 3.5 in an XJ than an LS. It may wind up cheaper, though, if only by a gauge set & a radiator. The $600 Novak isn't the only way to keep an LS cool, though.
Out of curiosity, what were you thinking as far as integrating the engine harnesses? General principles / best practices might be found by looking at (I know, I know) LS swap wiring guides, especially those concerning putting them in the GMT400 chassis as those trucks already have wiring harnesses for MPFI.
I'm not advocating some sort of change to everyone's mindset here, but it is a little concerning that some of you haven't bothered to read, but simply offer an opinion.
The 3.5 has forged internals, free floating pistons, cross bolted 4 bolt mains and 4 valves per cylinder. I don't see how 250 hp is pushing it too hard. I've read a few threads on other boards about boost and tuning because it was stout.
I get that an LS swap is the flavor of the month or that I can avoid swapping a drivetrain with a stroker. Both of those come with their own host of problems, such as cooling an LS with a $600 radiator or working out the fuel management of a stroker. An LS swap also means a custom gauge package, hood and accessory clearance issues and most importantly, me breaking stuff with 350 hp under my foot.
I was hoping to engage in a technical discussion on how to make this work, rather than a discussion on why it wouldn't. Can the 3.5l talk to the jeep gauges? Is there a way to mate the 42RLE to the engine and make the computers talk together? Does the bellhousing even mount to it?
I understand the work involved. I don't need a lesson on an engine swap. I've ridden in an LJ with an auto and it drives just like my XJ with an auto. I guess the technical expertise ofis limited to don't do it because no one has ever done it before.
