Dr. Dyno
- Al Ain, UAE
We're allowed to use different mounting brackets but we're not allowed to modify the mounts on the frame.
These modern turbo I4's are not such the high rpm engines like the old school stuff. If my S2000 had the power range of the Audi I never would have gotten rid of it. Expect the same of the GM.
Dyno plots?
Agreed 100%.
Peak HP and TQ numbers look great when you compare them on paper. However, where they make those peak numbers in the RPM band will be substantially different. Also take into account that your drive train gear ratios have been matched to the factory's low RPM torque band. You may find that to use 5th gear at all, requires 5.39+ gears for example.
I'm not sure what motor you would be swapping out, but you will more than likely be very upset that you spent so much $/time/effort to swap a 200hp I6 for a 200hp I4.
Personally, the ONLY 4 cylinder I would ever swap into a jeep would be a 1.9 TDI with a garrett turbo upgrade.
What?
Agreed 100%.
Really? The 2.0 turbo makes 260 ft lbs from 1700 on up to 5600 RPM. A new MAF (or was it MAP?) package & an ECM tune makes it 340 ft lbs.
At idle it might not be any match for the 4.0, so maybe not as good a crawler's motor without extra low-range gear reduction to get the RPM where you want them.
For my use, it would be just splendid. I mean, who doesn't want to lose 300 lbs up front & gain 100 ft-lbs in the driving RPM range?
Redheep said:Before you jump in and type about how you wouldn't, do some research and find a dyno sheet. The reason we're talking about using the LNF turbo motor is specifically because the turbo moves the torque curve back into the usable rpm range. The NA ecotecs have a traditional 4 cyl torque curve at a higher rpm.
These engines reliably make 260/260 from the factory at 300 lbs less than an iron jeep 4.0. It's not a honda race motor that needs 7000 rpm to produce power.
yes, because a 1.9l diesel with a narrow usable RPM band that makes 150HP is such an awesome choice. Then in order to bring it up to the 300hp an ecotec makes with just a tune, I'm gonna throw a thousand dollars at it's turbo, and since I'm now running out of fueling I'm gonna do fawesome new injectors, and then rework the IP with fat plungers. All so I can avoid swapping a lame 4 banger and make the internets love me....
Can we all get past the I know more than you and why you shouldn't do this and start on the let's figure out how to do it and see if it works plan?
It's really disenheartened to feel like you can't suggest anything new around here without people (including a vendor that sells his own turbo conversion) trying to tell you it will never work without any real proof. I'd much rather rely on their expertise to make it happen rather than fight about why it won't.
It has nothing to do with not being able to suggest something new, and everything to do with people giving you their opinion on it.
What expertise do you need? You already said that there are engine management options and people have stated all you need to do is fab motor mounts and drop the thing in.
Honestly, if you want to do it just do it. I started telling people about dropping a 440 in my MJ and plenty of people told me it either couldn't be done or was stupid. I still did it.
Honestly, I don't need anything. We could have closed this thread 2 weeks ago. What I need is $3000 and a couple weekends. Until I save up for that, everything we're talking about is moot.
When a vendor with a ton of self proclaimed turbo knowledge jumps in, you'd like to hear him talk about what you'd need to do to make the power more usable if he thinks it's not. Not get told that it simply won't work. Otherwise, he could just not say anything at all. :cheers:
I guess you've never heard of HPA? A company that actually specializes in TDI Jeep conversions. 1.9L's of fawesome that can actually produce 300 ft/lbs before 2000 rpm + 30+MPG.
www.hpamotorsport.com
it's a stock turbo with nothing more than a K&N intake and a downpipe.
so yeah, he's probably running up against the limit of what the turbo can do at hgh rpms.
still, the stock setup bolts to a jeep trans and makes those kind of numbers with nothing more than a tune and a different exhaust. Since it would be shoved into an XJ You can plan on sneeding a different downpipe and exhaust anyway.
