dgrigorenko
- Big Rapids MI
You guys got hooked like big fish. This thread has been totally derailed from the very beginning.
:cheers:
yep i did... wow... i was laughing the entire time tho... shouldve known
:cheers:
That was the most informative tech presentation I have ever seen, I am going to open my own turbo encabulator repair shop now with all my newfound knowledge! I've heard they are working on a far more efficient thermonuclear turbo encabulator! That should shut those hybrid geeks up for a while.What about if you are running a turbo encabulator? http://www.youtube.com/watch?v=MXW0bx_Ooq4 Would that help out at all?
Nah, that's only needed on cast iron.That should work. Is post heat necessary?
I think I just pissed myself...:thumbup:
However, everyone knows that you can not run coil overs without some sort of axle locator; this is where leaf springs come in.
I don't want to end up like this tard.
If that guy had a 14-bolt his Jeep wouldn't have tipped. It'd be wide enough and heavy enough to be stable on an extreme sidehill like that.
He might be able to run coilovers as well?
Everyone knows the 14 bolt is THE BEST axle to use for offroad use.
Is there a bolt-on kit for that 14 bolt?
Yes, it takes 14 bolts though. The mod might be over your head.
Don't forget to factor in the driveshaft, the OEM style cylindrical driveshaft is not rated for over 4.5" of lift (that is why the RubiconExpress 4.5HD kit is so popular).
What if I use like 8 or 9 and just over tighten them just a little?
This will work, but you need to tighten till the just start to strip,then back off a quarter turn. You might want to look at the 10 bolt option. Almost 25%
less work.
Yes but make sure you use the lock staples to keep the bolts from backing out.
Grade 9 in triple shear or don't bother.
