Installed a fresh Wix air filter in my XJ. Took out the IAC thinking it was dirty and sticking causing the high idle. It was clean as a new one. I don't know where to look next trying to figure out what is causing it.
Have you checked for a vacuum leak?
Not yet. It has just recently popped up. I'm going to try and sort it out over the next few weekends. Hopefully I can find it.
I have a whole workbench full of parts!
Oil change due on the WJ.
Need to put a new CPS in the ZJ.
Have a brake line, calipers, steering gear box, and axle seals for the XJ.
I foresee a little bit of garage time this next week or so. I have to get the ZJ done first so that I can move the XJ over to the side of the garage where the tool chest and work bench are.
cut the seat mount out the XJ last night...... Trying to decide if I want to loose the flat bottom in order to mount my suspension seat or if I want to put the 2 door seat back in and keep the flat with frame rail bottom...... Which would require me to remove the 205.....
