Lowrange2
- Abbeville, SC
You asked for a picture of my seat brackets. There's no need. Mine look EXACTLY like yours...
I thought you said you were going to get the Ultras?
Ordered the steel to finish my bumper. That's progress, right?
Got the transmission put back in Wendy's ZJ. Still working on a few other things with it. I'm going to remove the check ball in the transmission cooler line because they've been known to stick with age and burn the transmission up. Only drawback should be it may take a few seconds to refill the torque converter first thing in the AM. Small price to pay for the peace of mind I guess (especially since I won't be the one driving it lol)
And since the early ZJ NP249 t-case used a two-piece output shaft with a viscous coupler (as opposed to the one-piece shaft in the later models) I decided to swap to an NP242. Problem is that my 242 came from an XJ so the input shaft is too short. To compound matters, my 242 is also from a '94 model and in '95 they switched to a different gear pitch on the input, so I couldn't just swap them out. I found all this out after I'd already bought the 242 but it's not a huge issue since I can do the "249/242 hybrid" case. I'll use the front half (transmission side) of the 249 t-case, and the rear half of the 242 t-case. The 249 & 242 share the same front half case so the swap is fairly straightforward from everything I've seen about it online....so I dove in last night:
The victims; 249 up top, 242 on bottom. Notice the different input lengths.
Tearing the 242 down
MUCH better than the viscous coupler for our use!
And I also completed my first successful attempt at putting together an exhaust system. I've tried numerous times in the past to build a makeshift system that worked without leaking, all to differing levels of failure. I wanted this one to be done right since my wife and child would be riding in it. I had a good used catalytic converter that I installed, plus a Walker muffler from RockAuto. I know it doesn't sound like a groundbreaking achievement, but anyone that's ever tried to put an exhaust system together from pieces at home knows how frustrating it can be to get all the pieces to fit together just right, never mind the fact that Jeep decided to throw a curve ball and use a muffler that uses a 2.5" inlet and a 2.25" outlet! The correct muffler to fit this whole mess was only $21, and I already had the piece of pipe from the bogger-welded attempt that was in there before (that leaked like hell) so I'm very happy with the outcome vs. money spent!
I started to P.M. MEMBERSHIP and remembered that I had too many messages to ever get a response (don't get as many when black)
I phoned a friend who still has an active Paypal and used that instead. She'll just have to give me my new sticker when/if it ever gets there:rof:
He just got married over the weekend, he'll be getting things out soon I'm sure.
P.S. you suck!![]()
Sounds like my life. Put out one fire and another one pops up.
HYBRID: noun\ an object consisting of mixed parts designed to perform in unison to achieve a single goal.
Use: With parts from 6 different vehicles on it, my Jeep is a true hybrid.
