highspeed
- Owens Cross Roads, Alabama
I have it installed.I had to remove the bracket that is on the side.Smple to do just drill out the rivets with a 3/16" drill bit which are on the top plate.2 3/16" size rivets for the 2 90* brackets in the location facing up and bolted that to the header panel,drill holes of course.The one that I installed the bottom bracket stuck out then bent down 90 * I bent it to be flush with the cooler and cut off the rest to just above the header panel where the bottom portion of the grill sits.The one in the pic on EBAY looks like it may be flush all ready on the bottom.I will get some pics later today.Of course I did not pay that price.$20 from my local pull a part.I just need to make a small flat straight bracket for the bottom,have small rubber hose portions for now to keep it from rubbing the hoses.It sits very close to the grill so careful positioning is required but not hard to figure out.
Awesome, I would be interested in seeing how you have it mounted. There are tons of these explorers at the PAP in Huntsville and I can do this in an afternoon. Good insurance for my trans.
