- Rainy side of Washington
If I have to pull the engine for any reason I won't be driving it anywhere
it will be incapable of moving under its own power.
Have you tried running it on Everclear? It should go REAL fast... for about 20 feet. Then it'll pass out.
If I have to pull the engine for any reason I won't be driving it anywhereit will be incapable of moving under its own power.
Nope. I don't have 78 gallons of Everclear and if I did, would be doing something else with it :cheers:
Also, alcohol has an octane rating of 120+... that is far far too high for this engine. I don't have an engine hoist large enough to reach the middle of the grille nevermind the top of the engine, nor strong enough to lift this engine, so I am trying to not break it for as long as possible.
I think I will need to get my WJ brakes and 8.8 with discs installed before I attempt towing 20klbs with the XJ :roflmao:
That, and a 231-231-231 tripler with an Atlas behind it or something.
That actually happened to me once......a loooooong time agoand then when it wakes up it will have sharpie all over its face.....
I'll let the picture speak for itself but following the old phrase from Britney Spears "Oooppps I did it again"
Lennie uses a tow truck with a boom on it to pull heads and motors on dump trucks and big trucks.
How much you want for the back half of the cab!? I neeed it.
wait a minute, what happened to the last jeep YOU cut up ?Oh crap...raise your hand if you remember what happened to the last jeep he cut up....:wave:
Just messing with you dave, looking forward to the rest of the build.
