94xjsport94
- Carrollton, GA
Yep. You're close to AOP, Windrock, and Golden.
Almost ready to wheel! got to seal off the front wheel wells, move the rear bumpstops, and find somewhere to wheel
Just when i thought it couldn't get any more ugly!![]()
Things are cheap to build. 35 spline chromos, side gears or spool, gears, cover, brackets, brakes...
Why not run a 14 bolt? Then you dont have to upgrade to 35 spline.
Boat, I mean rock anchor. :conceited
Put a Barnes cover on it and cut the bottom off. :conceited I've seen way more 35 spline chromo rear 60 shafts break on 39s than I have a stock 14 bolt shaft.
Behind a stock 4.0 and 231?
Whats your tire size goal?
4D's.
Moparmaniac is running one is his rig behind a 440 and atlas... I'm not that crazy on the skinny pedal.
You can put less money in a 14b and have a better axle. Plus they can still be found about everywhere. Shave it down and its no worse clearance wise than an 8.8.
Its the path of least resistance, i have seen many a rear 60 break. Shave, disk brakes, weld or spool chunk and done
Yeah if you are going to run 40s there's no question between 14 bolt and 60 IMO.
Packing for Morris Mtn. ORV. Leaving in the AM for 2 days of riding supporting wounded warriors.
I was going to go, but my jeep needs work and I couldn't find anyone with an open seat tomorrow.
