If you have a pre 97 then you can easily modify the stock hinges for lift off removal. It'll be a ton easier than trying to adapt wrangler hinges to an XJ door and door jamb. Just cut off the lower ear from the door side and trim the pin up. It's what I did, and works great.
Did you get any sagging after this conversion? The driver's pin doesn't like to stay down now and that side sags a little because of it. Sounds like a great idea though.
the only question i have, is will my xj be legal on the road with no doors. i know the wrgler guys are all set, but are there any laws saying "if your supossed to have 'em you gotta have 'em" ?
I don't know about your state but here all you need is a mirror on the drivers side. No law saying you must have doors but one saying you must keep yor car , truck safe ??? So its up to each cop weather they think it is safe or not some here dont care others do....
Around here, I think it's technically one outside mirror, but I've never had problems without. Cops around here generally don't bother with things like that. Cops in your area may be sticklers for that type of stuff.
VA has a 4" door lip law, stating that you can legally drive without doors as long as you still have your mirror and a 4" lip at the door sill. Guess what the XJ's door sill measures EXACTLY.....4"!!
