TO DO LIST
1. Replace batteries
2. Add bumpstops to rear
3. Break tires down & hope its only mud causing them to leak down
4. Check & top off fluids
5. Pack tools & parts
1. WJ Brakes and upgraded steering - NOT GONNA HAPPEN
2. WJ Power Steering pump and cooler - COULDN'T GET ONE NOT TO LEAK, STUCK WITH THE OEM VERSION
3. TREs
4. Ball Joints
3. TREs
4. Ball Joints
Where were the pumps leaking from? First WJ one I swapped in leaked horribly from the shaft seal, but that may have been my fault when moving the pulley over. Second one is doing great as of right now!
My To-Do list grew a little:
Find 40" tires and wheels
Get my Jeep back from Will that's doing the tube work.
Completely build the 1-tons that I bought
Other things on a list that's a mile long.
Scratch all this... No way I'm even going to try to get all that done before the Crawl.
My ToDo list includes:
Load DD Jeep on trailer behind RV
Pack Clothes
Drive to Kentucky
3. TREs - DONE
4. Ball Joints - Half Done
The connection shaft between the reservoir and the pump. I reinstalled it 3 separate times and with a different o-ring each time and it never stopped. To that end, I did use a junkyard unit, so perhaps that was the issue.
I'm down to try and make the brakes better.
Load it up.
Drive 13 hours.
Wheel!!!!!
Oh wait...still have a little over a month :(
Looking less and less likely that i'll get much if anything at all done on my list before Harlan.
Finish the swap to 35 spline front stubs. Done!
Fix traction bar
Install harnesses
Redo rear chop...
Not break anything else...
3. TREs - DONE
4. Ball Joints - DONE
5. Tighten up all suspension bolts
6. Oil and filter change
3. TREs - DONE
6. Steering gear box
8. Try again with the WJ power steering pump
At this point I'm having so many problems with the tow rig. I'm going to have to hold off on a lot of mods for the XJ. I'm just going to have to get it good enough to wheel. And concentrate on the truck and trailer.
2. WJ Power Steering pump and cooler - COULDN'T GET IT NOT TO LEAK, STUCK WITH THE OEM VERSION
3. TREs - DONE
6. Steering gear box - DONE
8. Try again with the WJ power steering pump - JUNKYARD ONLY HAD 4.0 L WJs TODAY (denied)
9. Oil and Filter change - DONE
10. Radiator flush and fill
11. New draglink - DONE
12. Get driveshafts checked for balance and good u-joints (something is still making a vibration!)
13. Replace steering stabilizer -DONE
14. Chase that final steering "clunk"
15. Charge A/C
Fix traction bar Done!
Install harnesses Done!
Redo rear chop... Not likely to happen.... still trying to decide what to do.
Not break anything else...[/QUOTE]
[/QUOTE]
I can help w the chop part......
I can help w the chop part......[/QUOTE]
The chop part is not the problem. It's tube bending and rebuilding that is. :cry:
