To Do List
i wheeled mine bent for a few months after.and had no plans on retiring it if it didn't get worse
then fire came
Hmm, that gives me an idea... Colin where you staying at night?:firedevil
Install the rear D44 including disk brakes and all that
Rebuild the D30- gears, new locker, convert to one piece shafts
Fix my CB wiring
Fix my headlight and fender
New rear driveshaft
OBA
Im going to try to make this-
the wife is pretty psyched for it too!
to do-
install front hitch reciever OR buy new bumper
install lift(LCA's,bastard pack, shackles, and springs)3+"
install jcr sliders
install rock ratz rails,but not on the cab, on the bed
install gas skid
install cb
put linkage and shifter in for t-case
maybe put the 8.8 in
NEED
tires(33"or so)
brake lines
front shocks
uh put engine from 93 into 98, drive to nac fest, ride beotch
i know it aint gonna happen but if the 95 was to make it heres the list
frt 60, gears, locker, mounts, steering, drive flanges, 35 spline stubs
rear 70, weld diff, mounts, brakes
install trans from 93
buy and install atlas
driveshafts
bumpers sliders and cage
skids
floors
buy tow rig and trailer
maybee i should sell a kidney and a lung so i can take the 95 to nacfest
heres my list
install front and rear axles
front tow hooks
rock rails
fix cb wiring
gas tank skid
t-case skid
...all i can think of for now
Guess it's time to codify my list:
1. Install HD tie rod
2. Paint/Install JCR TCase Skid
3. Install lift parts (to get from 2" to about 3")
4. Source/install new power antenna
5. Fix power mirror wiring
6. Readjust deflators from 12psi up to 18psi
finish rear bumper and put that on
put in new front shafts
winch controls
disc conversion
WJ booster/MC swap
new drag link
figure out why my ARB doesn't work
Added a few more things to my list...I think I'm supposed to cross stuff off not add stuff...damn it
WJ booster/MC swap is now a must. My master cylinder has been crappy for a while but it's to the point now where I cant drive it...gonna try to do that this weekend
I suppose I have 2 "to do" list options:
Common items:
-Unibody tie-in's for rear bumper
-new front bumper mounts (unibody tie-in's)
-maybe a winch on front bumper
-maybe/hopefully rock rails - CHECK [pending]
-SYE - CHECK
-hopefully skids - CHECK [pending on whether they are sold yet]
-297x D30 shafts - Added - Hopefully taking care of this this weekend
Axles option 1: - CHECK
-XJ width 9" rebuilt
-regear D30 - (with truetrac and diff cover)
Possibly long arms
So I have come quite a bit further than I expected already, updated items in bold... The bumper tie-ins are just a matter of picking up some steel. And the winch/long arms I think are largely dependent on how the taxes look.
I really hope the guy with the skids that I emailed gets back to me soon... That would knock another item off my list.
heres my list
front tow hooks
rock rails
fix cb wiring
gas tank skid
t-case skid
very tempted to break out the credit card and take advantage of JCR's current sale and get some good bumpers, and sliders :spin1:
shall i be the first to do a list for this year?
to do:
-get axles from travis and swap them in done
-design and fabricate 3 link and cross member mostly designed
-weld on ruff stuff stiffeners
-make 3x3 angle iron stiffeners for the rear of the unibody
-make shock hoop things that go through the floor for the rear shocks and rework rear bumpstops
-fix lots of rust (this one could take quite a while) in progress
-weld in 2x6 rocker replacements and tie into unibody rails
-swap transmission/transfercase(s)
to buy:
-DOM and rect tube for 3 link and crossmember need DOM still
-tube adapters done
-joints for 3 link done
-clutch
-rims and tires (haven't even decided what kind i want yet)
i also decided to make a doubler out of a np231 front half and a D300... so add that to my list.
i'll be lucky to finish for fall crawl. but if by some miracle i'm done by nacfest, i'll be there.
You could totally make fall crawl. Let me fix that list for you.
This is all you have left that you NEED to do.
to do:
-swap transmission
to buy:
-clutch
And skip the doubler for now. Build it over the summer. You're totally going to regret not being able to go.
its more fun to wheel now than build stuff for later
I figure once my rig is up and running that leave me 1-2 weekends per month of wheeling and week nights and the other weekends to work on the Jeep. My goal is to upgrade but to keep the Jeep in a functional state at all times. I.e. a new transfer case will not go in until I have it completely done and have everything I need to fully complete that part of the project.
...That coming from a guy who hasn't driven his Jeep for more than 5 hours in the past 20 months :rolleyes: Maybe I should just go shuddup until I get out wheeling at least once.
nope. doing it once, doing it right. i like building stuff just as much as i like wheeling.
