9T3XJ
- FoCo, Colorado
I have been researching steering setups for a while now and came across the OTK setup that goatman used on his D30, i think i'm going to copy it using 3 TRE's from a grand cherokee and 1 heim.
I have a couple of questions thougth:
1. when you guys tap the ends yourself, do you just tap the ends by hand or do you use a drill press or a lathe.
2. this is for goatman, i'm curious about what you thought of this set up vs. the inverted T you run on your D44. i'm thinking the inverted Y would have less clearance issues then an inverted T on the 30.
