The Stupidist Jeep on the Planet
Re: Just a Cherokee on tons
Great imagination. lol
got some goodies in the past couple days
first some .25" wheel spacers, need em so my super cool crome lugnuts wont bottom out on the rear 60, it does say not to use em on station wagons or off road vechicles so i guess im screwed
also got D70 simple swap kit and disk brackets for the 60ISU the disk brackets need to be extended a 1/4" other then that there perfect for a 60 isu
got a 3 day weekend coming up plans include, pull crossmember and redrill holes to shift trans to the pass side, make spacer for trans mount, make mounts for 60, weld new spring perches to rear 60 and get that under jeep
LCA mounts anyone:yelclap:
since all the buggy guys are goin with alum links to save wieght id figure id 1up them and use pvc links
got lca mounts and the bases for my coil buckets welded on yestrerday(thanks to nhrocker for welding it all up), lca mounts will get boxed in a little and coil buckets will have 4"od tube in the middlle to hold the coil in place, i just wanted to get the lca mounts in and coil bases so i can figure location for uca mount and control arm lenths
Pics
nothin much goin on at the moment due to lack of funds, right now im workin on relocating all the shifters closer to me, picked up some Miata seats last fri, they fell real awsome, and theres some D30 stuff thats gonna go onto my D60:eyes:
nothing to cool goin on at the moment, hopefully in the next few weeks it can be upgraded to roller status, but for now..
got some miata seats from 5spdxj
also, ive been tryin to figure out a way to secure the coil from moving around, and found the solution...
look familier, its part of a d30 unit bearing minus the 3 mounting flanges, works perfect, just needs to be welded
trimming has started to fit the 38's(It was trimmed for 35's before), the frt axle is pushed forward 1.5", next week i will be working on the uppr link for the 3 link and steering
goodbye horn braket
header panel, meet mr swampah(im gona add a chink of tube behind the header panel to protect it from the tire)
more sheet metal goin bye bye
looks like the floor will have a date with mr bfh
not bad
some orange things are bout ready to break out and make there way onto the 60, plan is to do so tomorow after work, just need to getsome locktite, grease and nuts after work tomorow
and just because i cant instal pretty knuckes with rusty parts i painted the spindles, brake brackets and hubs(hubs are from cali so are rust free)
If you decide the orange things won't match your paint scheme I'll buy em for the same price as I'm buying those other things :)
only if you paint your axles blue
I think those orange things would be very nicely complemented by a set of axleshafts with orange things on them
you wanna donate the money cuz that aint gonna happen, the 60's will get 10 factories, o and just cuz i can
FRONT DIG!
got Ried knuckles and Balistic hi steer arms on the 60, fri i will make the brakets for the upper link and tb brackets, next thurs i will be ordering 10 factory shafts for the 60's
gorgeous
