Fan bearing replacement on 89 with A/C
Cox89Limited
Huntland TN
Can the fan bearing be replaced on a 89 CJ with A/C? I know the fan bearing can be replaced on 91 thru 01 XJ’s, but I can’t replace mine on a 89 XJ limited
So I’ve bought a new Taurus fan and shroud for a 93 Taurus and will be replacing it tomorrow.
I mistyped XJ not cj
Clutch Fan Bearing, 808129 41-71 Jeep impeller bearing this is the part to replace the fan bearing with. There are a few videos out there showing the procedure, I have a press so it was rather easy. The extra length on the back does not impede anything and can be left, make sure to note how much comes out the front.
I bought a bearing and when I went to press it out it will not press out the back like every video I’ve seen. Renix jeeps have different components than mopar jeeps
My bearing housing cracked before I realized it couldn’t be done like the video’s I’ve seen
To late for me but I would love to know if it can be done on a 89?
My jeep is an 88 RENIX and I had no problem changing it.
