Should of 4 linked the rear
Thinking that may be a project for next winter.
So what's the wheel base now?
Still at 102". I moved my frame side LCA brackets back 1", axles stayed in the same place.
I'm really surprised by the 5" BDS leaf packs. They seem to be quite a bit longer than their 3" pack, which helps with shackle angle, and they center the tire in the wheel well. We'll see how things work out, I can always kick the rear back like you did if need be.
I'd honestly love to end up around 106-108". However, that's not going to happen with the factory coil/leaf setup.
Time to start of fabbing up the upper link, which meant removing the stock frame side UCA mount. Sliced off most of the mount, and then ground off all the remaining spot welds for a clean slate.
I drilled a series of holes along the inside edge of the of frame to give me a reference point for the hole layout. Then it was commitment time.
I needed a strong platform to mount the upper link bracket to, so I made a reinforcement plate out of some 3/16" plate to weld to the inside frame.
The plate spans roughly 16", and I drilled it for plug welds. Here's a little trick when it comes to transferring hole locations if you don't have a transfer punch. Position the bracket over the plate, put some grease on the end of the bolt, and then slide the bolt into position. The grease will reveal the bolt location.
I ended up moving the bracket forward about a 1/4" inch, which meant the 1.5" hole I just drilled was off. I could have enlarged the hole, but had another trick to correct the problem. Find the hole saw cut out, weld it back in place, grind until it's smooth, and recut your hole. It's just metal, take it, and add it as you please.
Inner frame plate in position. You can also see I cut out more of the floor for the upper link to travel. I still need to fine tune the cut out once I cycle the suspension.
Glued my upper link bracket all together.
Mocked up the bracket for 25" back from axle centerline, and 26.5" off the ground. Tacked it into place, and then added some reinforcement plates for the floor. I still need to add some gussets from the bracket to the floor plates. I think once this is all welded together, it'll make for a really strong mount. My passengers are just going to have to suck it up when it comes to foot room.
I'm pretty happy with how the upper turned out. It was a sacrifice bringing it through the floor, but for the vertical separation (7") I was after it needed to be done. My only worry is clearance between the upper, and the starter under compression. If needed I can move the axle side mount out for clearance, but I won't know for sure until I can cycle it.
I also don't have a clue how I'm going to enclose it all, but I'll worry about that later. To be honest, if the noise and incoming debris isn't too bad, I'll probably just leave it open. :dunno:
