- WA state
Care to give me a GREAT deal on your current axles when you pull them?
Good to know, Tim. I'm going to try my best to make it down. It would be nice to meet up with theWe will be going to koh again. Let me know if you want to setup a Naxja camping area.
That depends if you won big in Vegas or not?Care to give me a GREAT deal on your current axles when you pull them?
Tracked down a 150PSI preset regulator. Western Enterprises #RP320150.
Pretty simple setup. Tank, regulator, hose. Just need to figure out a good mounting system, and I'll be in business.
Well you have had plenty of time to test this part.
How is it working for you?
How long does it take to fill one of your 33's?
Thank you
Jason
I have the same setup, "my" thoughts are, it's one of the most reliable sources of air due to the lack of mechanical parts, Buy a decent hose and a clamp on style tire chuck, and you're set.. Also, With that said, one tank of Co2 lasted way longer then I expected.
My CO2 setup has been trouble free from the get go. It just flat works, which is what I like. I don't have to worry about oilers, filters, or having my rig running for it to work.Well you have had plenty of time to test this part.
Thank you
Jason
I have a similar set-up, but not sure the pressure on the regulator, right off...
It takes forever to fill one tire. Might look for the regulator you have.
Thank you
Jason
Might be your hose or chuck. Iv seen chucks slow air-up time down.
Thanks, man.Hey Dustin, I just re read through your entire thread (well minus the last two pages cause I wanted to leave work on time). Even though I've read it before and seen it in action your craftsmanship and attention to detail still amazes me.
I read through it again to get a better idea of basic maintenance things I should do since I just got my hands on a pristine, lovely cherry red '99. Coolers and 2awg grounds are very close to the top of the list.
Thanks again for documenting your build so well, and giving me inspiration to build a rig that hopefully in the next couple years will join you down in Moab and rubicon!
