BoringDave
- Boring
You bought Phil's Toyota ?
That's funny!
Nice! I too just got a Rear 60/HP44 setup.. Of course.. I'm "building" them.. Tire size in mind? I'm going 37s
Thanks, old timer.I'm always so impressed with your skills for such a young man.
Bunch of vultures already circling.Torx! Perfect timing! Are you wanting to sell your 8.8? Let me know when and how much you are wanting for it!
You know I'm a huge advocate for building everything I can, but in this case it just made sense to buy what I wanted. I'll be redoing a lot of the brackets, and customizing them for my application though. However, already starting with narrowed, geared, locked, and alloyed axles was a big plus.Nice! I too just got a Rear 60/HP44 setup.. Of course.. I'm "building" them.. Tire size in mind? I'm going 37s
Oh, you guys and your fancy big a$$ axles. I would have no problem using 40's on my 30/35 combo locked cocked and ready to rock!
I really only passed on two obstacles, Escalator and Rock Chucker.So I noticed in your MOAB Trip report, you mentioned opting to run several obstacles "next year" .... You didn't go in depth with much explanation for this, so I'm curious if it was because of your confidence (or in this case - lack there of) in the Nail Salon, or if it was just cold feet? .....
Also did this trip leave you wanting something more out of the XJ?.... It seemed to have performed well enough for you, but it also seemed like you may have a "want to do/need to do for next time" list now now that your back......
Obviously the new axle set up is going to be amazing, but I cant imagine that your axles were the only thing keeping you from running some of those obstacles.
I always carry goggles with me. The plan is to always drive it home.a 1000 mile drive home with no windshield after a flop is all part of the experience LOL
Thanks, I'll have to look into that place. Since I already have my old OEM alternator I figured it would be easiest to have that rebuilt rather than buying or sourcing a new ZJ one. I don't run a ton of accessories, so I really don't have a big need for big power. Just thought a minor tweak might be nice.Awesome photos as always.
I'll be interested to hear what you decide to do for an alternator upgrade. Auto Battery and Electric on SE Hawthorne in Portland is one place I know of that should be able to rework a stock alt for higher output. I haven't used them for that yet, but they were super helpful when I needed a smaller alternator pulley once before. I assume you want something higher output than a V8 ZJ alt which IIRC is about 130 amps? Any plans to relocate it higher up so it doesn't go for a swim next time?
I don't know what you're planning to do with your existing axles after you swap the 44/60 in, but since 90xj called dibs on the 8.8, I might be interested in the D30 depending on what gears & diff are in it, if you'll be wanting to sell it that is...
El junky was a good read, and you do know I was just joking right?
If anyone passed it up go read that tread. For real the guy is using 40's on a 30!
