if it has tow mirrors, buy it!!!
don't care about abuse/lack of maintenance. People are dumb. Can't blame the hardware just because you are a moron.heat, heat, heat, heat, too much power, heat, design issues, and heat.
e: oh, and abuse and lack of maintenance.
That'd be Fisher :lecture:it does. oh and I forgot it has a plow mount. I think its a fisure or how ever you spell it. he hasent done much plowing with it though.
Please excuse the dumb questions, I've always just assumed automatic trans sucked and never investigated why. Heat from where? Internally generated heat? Don't people use tranny coolers with quality fluid and a decent torque converter?
Automatics seem like such a headache, and for what gain?
I would never buy a tow truck with a stick shift, not one that I wasn't driving 100% of the time. Or any vehicle that wasn't mine to drive. You can't **** up the gears, clutches or anything else do to operator error on an automatic
They have a lot more funky moving parts and stuff than manuals, moving parts = friction. If the clutch packs slip, it makes more heat obviously, and the torque converter by design kinda makes some heat when it's not in lockup mode. Hot ATF wears out faster, and wears the clutch frictions faster, if you don't maintain them properly or overheat them or both, it will cook it.don't care about abuse/lack of maintenance. People are dumb. Can't blame the hardware just because you are a moron.
speaking of stupid, got in my 6" Pypes exhaust tip today
is it a terrible picture?yes, can you Kinda see the tip?probaly, do i give a shit? no
and haow many of those are due to lack of maintnence? or low fluid? theres still a ton of ZJ's and Dodges on the road with the origanal trans at 200kThey have a lot more funky moving parts and stuff than manuals, moving parts = friction. If the clutch packs slip, it makes more heat obviously, and the torque converter by design kinda makes some heat when it's not in lockup mode. Hot ATF wears out faster, and wears the clutch frictions faster, if you don't maintain them properly or overheat them or both, it will cook it.
Some run hotter than others. Supposedly the AW4 is one of them, I've cooked two and I'm working on a third but they were all due to pretty horrible abuse, I don't blame the AW4 for that since no one else has issues with them. The 46re and related transmissions? eeeeeeeeveryone has issues with those, except apparently Colin's friend who knows how to build them and run them. Every other ZJ on CL around here with a 44/46 is listed as having a slipping tranny or one that was "rebuilt only 20k miles ago", or at least they were when I was looking at cherokees and kept finding grands.
so I got more details on that CTD I was talking about.
its an 01 3500 dual 260000 miles.
all new tires, bunch of new stuff in the front end like bearings and ball joints and stuff, new transfer case. only thing is it doesn't shift into overdrive.
I think I could probably buy it from him for around 6-7k.
sound like a good deal? its better then all the stuff Iv seen for sale around me.
milage is kinda high. but the CTDs are supposed to run forever
Your logic is undeniable. I think you raise a good point about a lot of these being shared vehicles.I would never buy a tow truck with a stick shift, not one that I wasn't driving 100% of the time. Or any vehicle that wasn't mine to drive. You can't **** up the gears, clutches or anything else do to operator error on an automatic
Letting someone drive your car with a manual trans is like letting them borrow your girlfriend.
