Teaser Dana 60 Build
Oh my, I am in heaven! This thing is gargantuan! That is a refrigerator dolly it's laying on. This thing has everything including ABS. $250 plus I paid him $30 to deliver it from Tacoma. Very sweet. It will be hard keeping my hands off of this and staying focused on the rear 60.
JeepFreak21 said:
A Dana 61 is not all bad... depending on your goals! What gears/locker/shafts are you interested in running?
Billy
My plan is to have 4.10 gears, ARB, 35 spline shafts. That way my jeep will fold like a taco before the axle breaks (wife said that).
Ba-Riedo said:
Christ Jeremey dont you think that 37's are overkill in the NW? It is gonna be sweet to see this thing when its done.
-Alex
I will need 37's to clear my 60's:scottm: . Besides don't believe that, "I can run any trail on 31's" or "there is no reason to run bigger than 33 in the NW." I can think of a few people who said that to me and later went bigger. Did they need to? probably not. inchitis? perhaps. But in the grand scheme of things 37 isn't so big :laugh3:
Update on that unidentified dana 60/61. I just got word that the axle has 60HD cast in the webbing. So I will hopefully pick that up this weekend. WooHoo!!
3 dana 60's? I'm thinking 6x6 :roll: :roll::roll:
And yes I am just kidding.
Yeah... 5.13 or deeper I would think, I'm running my 33's with 5.13s right now. The lower you go the slower you can go so less chance of breaking shit.
I will be running a diesel, they generate there optimal power at lower RPMs. And thus require very different gearing. Now I may need to go to 4.56 but the transmission I will be using has an OD meaning that the gearing is even higher. Never the less I can get stock gearing for cheap. The 60HD is already 4.11. The current rear 60 already has 4.88 gears which I will leave in so that when I run with gas It will help my mileage on 33's. I will then build the 60hd for a clayton rear coil conversion application with the 4.11. If that works with the diesel great. If I need to go lower nothing lost. And I'm sure I have mixed up my higher/lower refrences. Does that make sense joe?
When did you go 5.13? do you stil have you d30 4.88's?
yeah makes sense, so are you building another rear 60 then?
EDIT: I would still go lower just so you can have a lower crawl speed
Yeah, this one has tapered spindles that I can't bore out to accept 1.5 35 spline shafts. So I am gonna finish it as is and make it a direct bolt with leaves and run it to see how I did. Then I am gonna build a Dana 60HD that I am picking up this weekend that already has the big bore spindles and may already have 1.5 35 spline shafts. It also has more reinforcing on the housing.
I am looking for DD fuel economy. I may run a doubler later.
EDIT: Also I will be running a 700r4 which has a lower 1st gear than the AW4. 3.02 vs 2.80 I think, Eli?
cool when you're done with that 60 PM me, depending on when that happens I might be interested in taking it off your hands.
WaXJ_Skier said:
Yeah... 5.13 or deeper I would think, I'm running my 33's with 4.88s right now. The lower you go the slower you can go so less chance of breaking shit.
fixed I was thinking about my next set of gears when I end up doing a front 44. Stupid dreaming whiole posting.
FWIW I've had Chevys since I could drive, all with 700r4 and 4l60e (the electronic variant) and 35's. I've been through 4 trannys in 60-80k? I HIGHLY recommend a different tranny, especially if you think you can run 37 inch tires and 4.10s. Your tranny will hate you and you will know it.
Thanks for the advice, I will make sure to look at more options.
Ba-Riedo said:
why not go 39's? I mean 37's are so close to 35's and everyone has those now...
-Alex
Please oh please tell me you did not just recommend a tire size based on what the cool kids are rolling...
Besides at 39 I would have serious COG issues, I mean more than what I will already have.
