I've got 12-bolt H1s all stock, yet I'm planning to weld on a set of rock-rings before I run them.DrSockMonkey said:Are you H1's recentered? Different bolt pattern? Where'd you get em from?
Thanks,
Jeremy
I'm using them with full-width 60s, 8lug, so I'm not worried about the width/backspacing (only worried about the rash of beatings my drive flanges will see
IMO, you will be alittle narrow running them on your narrowed (60" WMS, right?) housing if you use the stock 7.25" backspacing. That's something you're going to have to measure before you get into them.
Edit: Thinking about it, be the wheels will be further inboard than stock using those dimensions. :shiver:
