1) 4688...John Currie............modified...00:00:00
2) 4581...Larry McRae............modified...00:00:00
3) 4558...Brandon Heyes..........modified...00:00:00
4) 4515...Mitch Funk.............modified...00:00:00
5) 4577...George Evans...........modified...00:00:00
6) 4535...Kevin Sacalas..........modified...00:00:00
7) 4538...DJ Harmon..............modified...00:00:00
8) 4646...Ferris McCollum........stock......00:00:00
9) 4612...Ben Varozza............Stock......00:00:00
10) 4669...Shawn Passmore.........stock......00:00:00
11) 4531...Shawn Rants............modified...00:00:00
12) 4569...Jason McAtee...........modified...00:00:00
13) 4666...Dan Hayes..............Stock......00:00:00
14) 4602...Ryan Kennelly..........stock......00:00:00
15) 488....Josiah Begay...........Stock......00:00:00
16) 4680...Cody Addington.........stock......00:00:00
17) 4621...Bret Scheiding.........stock......00:00:00
18) 4511...Alan Johnson...........modified...DNF
19) 4514...George Kane............modified...DNF
20) 4502...Barry Cherneske........modified...DNF
21) 4505...Jeff Rector............modified...DNF
22) 4692...Scott Hartman..........stock......DNF
23) 4643...Richard Gauthier.......Stock......DNF
24) 4664...Richard Williams.......stock......DNF
25) 4648...Brian Behrend..........Stock......DNF
Fyi. Currie is stock class.
Nope. Fully legal and beat a mod/basically unlimited class by 20 min
well, after having the alternator go out at the starting line as we were lining up (charging stud pulled out of the back), they had both front hubs go out and swapped them at the first pit. then the trans started giving them problems before the rear axle finally decided to go banana on them. We gave it a hell of an effort but it just wasn't going to happen this race.
I still had a blast helping with the car, thanks for the opportunity guys :thumbup:
re-tube the axle, truss that mofo for real this time, rebuild that tranny (and the torque converter, those things are weak usually) and get back out there!
here's a vid of the start, the stroker sounds so mean.
got our 1st pass 30 feet in :gee: that white XJ broke the rear driveshaft yoke going over the starting line.
Just one of the problems...
Was Cal driving?? XD
It doesn't look like it was the actual tube, just the shaft itself near the flange that bent?
Not sure, can't really tell from the pic.
Oh no, it's the tube.
Both tubes are also seeping at the pumpkin.
i would sure like to see a better pic of that axle where it bent. from my view it looks to be bent right where the truss ended and the shocks are mounted. that is a lot of stress at that point with 2 heavy duty shocks working against you. plus the truss may have weakened the axle tube at the weld point.
A happier time.
At least we made it back in under our own power.
Although some fool seemed to be stalking them.
The NAXJA salute.
