- Hammertown, USA
http://www.naxja.org/forum/showthread.php?t=978342
ask and i will search.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Here's a quick quote, since the good stuff doesnt start until 20 posts or so into that thread.
ok. Now that I'm at my desk, had some coffee, and had a chance to replace the cell phone I dropped Richards head on sunday morning.
First, Thanks Russ! You busted your ass and made a mess of your shop, but got the engine done sorta within our deadline. Much Apprciated!
Thanks to Mike Finch (willy51). He was there every day helping, and probably drove 600 miles running my errands.
Cal: "Hey, run to Sequioa's and pick up his 99 shortblock, I need a part off of it." Mike: here you go Cal: "Great! now run to Kyungs and do the same thing."
He's a trooper.
Thanks to Kris Tholke, Sequioa, Kyung and a few others for chipping in parts. Some were pretty minor, a few were far from minor.
For those who want to know
4.2 12cw crank
KB 944 forged pistons
4.0 rods
7120 head ported/polished
mopar performance 30ab cam (Thanks Kris!)
mopar performance valve springs/keepers/shims
late model main brace
cloyes timing set
Hesco high volume blueprinted oil pump part M167HVS
Clifford Performance blueprinted water pump
a lot of custom machined stuff
a lot of arp stuff
a lot of one-of russ stuff
I'm tired, the numbers are a big blur in my head, but iirc Russ cut about .060 out between the deck and the head, we're in the 10.5 cr range and around .045 quench
An entire day just building rods.
The KB pistons could have a better dish, but no time for custom.
This is one heavy crank, and it uses every bit of room available to it.
In fact, it uses so much room we had to make custom spacers to fit the main brace. Don't try this at home!Later, we had to clearance the oil pan both for the brace and high volume hesco oil pickup.
Oooh pretty!
I dropped the head on my 3 day old $500 cell phone just after that picture, so that was the last one I took. I'm sure Russ can chime in with more details on the motor at his leasure, but right now strokers are probably the last thing on his mind.
-C
