Lot's, lot's to do yet. Progress has been slow this week, nearly all of my time has been messing with the plumbing on the fuel cells, and a little bit of welding to beef up the frame side rear control arm mounts, and re-mount the amber light. Getting the 3 Walbro pickups in the main tank was a real PIA, and time consuming. I also found that I had no rollover valve in the other fuel cell like I thought I had. There was simply a rubber fuel hose attatched to the inside of the fitting, and that hose was deteriorating with chunks of rubber in the bottom of the cell. I removed the foam, removed the fitting to be able to remove the hose, and cleaned out the tank. The vent lines are properly routed, just need to install the ball valve. A new rollover valve will be here tomorrow, so tomorrow night the tanks and plumbing will be finished.
Still need to:
Replace 2 rod ends on the steering, and replace the bolts
Align front tires
Add gusset to frame side front UCA mount
Install axle side UCA mount and control arm
Install rear LCA's with new bolts
Install all four shocks and air them up to set ride height
Fix t-case vent line and route to new can along with the rear diff vent
Make new floor panel to cover the t-case
Remove bump stop pads and old coil perches from front axle
Install seats and new seat belts
Bolt down console
Mount up four new tires
Install cutting brakes
That's the stuff I "hope" to get finished by mid week next week, ready to head to JV for the weekend. When I get back then more stuff needs to get done, including replacing more bolts, torquing every bolt to spec and marking them with Torque Seal, moving the air line fittings, dealing with a second battery and ability to weld, making and installing new skins, installing all new stickers, changing the oil, building a heat shield over the muffler, pulling apart the drivers side knuckle to check the unit bearing, making an additional bracket on the pass side motor mount, changing the oil and filter, etc.
It's going to stay very busy.
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
