smcdonaldaz
- Litchfield Park, AZ
I'm going to do the upgrade, how much do they run at the yards?
No, your dealership is charging for a brand new part that is built to the same quality level as OEM. The junkyards are charging for a used part of unknown functionality.damn $10-$15 my dealership is realy ripping people off
edit: bout $185 i would charge a customer just for the part
Also look at crown Vics and mustangs.
X2, I never measured the amps when I had a taurus fan but I think it was drawing around 15 amps once it got going. The initial surge would draw less than 40 amps on mine.The high draw is only for the first few seconds at start up and not while actually running once up to speed.
$25 and some change (including tax, the $1 entry fee, & $2 core charge).
I actually got a Lincoln Mark VII 3.8L 2 speed fan. They are supposed to flow more air and use less amperage than the Taurus 2 speed fan from a 3.8.
Have you installed the Mark VII fan? If so, how was the install? The shroud appears to be a bit smaller.
I picked up the fan and the CCRM (Constant control relay module) that I use to power it for around $20 at my local pick n pull.
