DirtySouthXJ
- Florida
Hi,
There is a (ebay/amazon) triple electric cooling fan system (semi) installed on my 96 XJ by the previous owner, but he wired it by tapping into a fuse in the PDC (no relay, fans turn on with key on). It looks like an adapter was added where the factory coolant temp sensor was, in order to add a second coolant temp sensor for an aftermarket coolant temp gauge; so currently there are two coolant temp sensors at that location.
Here is what I would like to do:
- End up with a properly wired and functioning fan system.
- Install the aftermarket coolant temp gauge. Currently all I have is the idiot light cluster.
Questions I have:
- Would there be any ill effects if I were to disconnect the factory temp sensor and install a coolant temp switch in it's place?
- Is there a port in the intake, head or block that I can install a coolant temp switch in to turn the cooling fans on, to avoid having to splice an inline adapter into the coolant hose?
If not..
- Can anyone recommend an inline adapter kit (preferably with temp switch, fan relay, wiring etc.)?
- Does anyone know the size of the coolant hose (I'm guessing i.d. to fit over adapter o.d. ? )
Regardless of temp switch installation location..
- I see different coolant temp switch on/off temp specs (on 200°/off 185° etc.), what spec switch should I use in this application (96 XJ 4.0)?
Thank you!
Questions I have:
If not..
Thank you!
