I'm smack in the middle of a build sorta like Ashman's...a little more body left though (doors still go on).
It's been...interesting so far. A lot more work than I originally thought, which is saying a lot because I tried to plan EVERYTHING ahead of time. IMO, especially after the amount of crap I've done to mine, you need:
- full unibody reinforcement. Probably from front to rear, although it'll depend on your suspension style. I hate leaf springs so I'm doing a 3-link front w/panhard and 4-link rear, and the 'frame rails' are going to be plated from coil mount to coil mount. Especially in the front area by the steering box and panhard frame mount.
- full cage. You'll need this for torsional rigidity, and also personal safety. Important to both the life of the vehicle and life of its passengers. Tie this in to the unibody reinforcement at many spots.
- solid front/rear bumpers and crossmembers. Connecting the two frame rails will help keep everything together too. Mount the crossmembers to the reinforcement stuff.
They're tough vehicles to build, I'll give it that. You either have to be willing to work within the constraints of the unibody (and maybe make compromises in performance and clearance), or you have to be willing to put the extra effort in to modify the unibody and make sure that it stays together after it's been hacked up.
edit: To relate this to your original question, I'll be running around 5-6 inches of "lift" when this is all done.
