James
Have you looked at pictures on
www.xjdb.com?
Do we have any cherokee members on here on 44s? I dont know of any, so you wont get much help. Im on 42s.. close but not nearly as wide as 44s!
Here is one on 16in 2.5in coil overs, internal external cage, 2.5 ton rockwells..
lots of work..
This one uses coil srpings and 1ton axles more body.. but the 2dr body is sweet.
Here is one on Coils and 2.5ton rockwells, military tires.
Here's mine on 42s. Im swaping the front leaf springs for a 4link and 16in coilovers. I am happy I origionally did the leafs, it was realy easy to setup, and at the time I might not have had the skills/tools to do the front links correctly. the rear 4link was alot easier, no engine, frame clearance issues.
I vote for some Rancho 44044 leafs (with shackle in back) on the front that would be alittle taller then mine, probibly 2in taller, and do a rear 4link with 2.5in air shocks, TJ front lift coils, or 2.5in coilovers if you can swing it.
Check out my buddie Jeffs shop.
www.ballisticfabrication.com he sell mounting tabs and materials to build links and stuff.
