stroker plans
i got a stroker that was already built. had a crack in the block. so i'm going to get it welded up. it was out of an 88 wrangler with a 4.0 conversion.(stroker really).
i'm going to keep my stock motor complete just incase the weld doesnt hold. then i'll have my extra block machined.
wonder if any one has bored out a block on a manual mill (bridge-port).
taking classes at school for CNC. but the CNC is to small. and i cant do it on my Mill at work.
i'm going to keep my stock motor complete just incase the weld doesnt hold. then i'll have my extra block machined.-Ahh! you're the one that bought that motor off nc4x4!
taking classes at school for CNC. but the CNC is to small. and i cant do it on my Mill at work.-I thought that a bidgeport was just a large drill press with alot of options?
yes i did get that one.
yes thats basically all it is. it would take time but i think it maybe possible.
pick up the center of each bore using an indicator ceter it up so its vertical and use a boring bar to bore it open. sounds simple. but maybe i'm missing something
