7roy1117
- Laurens, South Carolina
I have searched through forum after forum and there is no answer in any of them to the problem I’m having. Last year the blower motor stopped coming on completely. Right before that it was in and out at random. I’ve replaced the control switches, blower motor, resistor, relay, and fuse. When I check the power coming out of the blower motor pigtail it is pulling a constant 12v. When I run my blower motor directly to the battery it comes on. When I connect the pigtail to the motor it does nothing. I can hear the blend door moving when I change the direction of air. But no air will come out. Is there a vacuum system that helps run the blower motor itself? If so what are the components called that could be suspect? I’ve been scratching my head with this for quite a while now. Any help or info is appreciated.
