vetteboy
- morganville, nj
Paul S said:It's been a long time since I had the WJ knuckles, but IIRC, the histeer arms on my WJ knuckles were about the same distance in from the KP axis as my PMP arms. Before I bought my PMP arms I argued at length with Mike that his arms would have terrible Ackerman, he insisted that they wouldn't & finally offered to take them back if I didn't like them. He was right, they're perfect, but the KP axis is nowhere near what I'd call proper Ackerman.
Paul
Well, that's how you set up Ackerman lines to determine tie rod mounting etc.
But...I think that it assumes you'll have a zero scrub radius as well. I'm pretty sure that it's most accurate when the tires rotate directly on the ball joint axis. Any scrub radius you add on top of that (less backspacing, wheel spacers, etc) will adversely affect the Ackerman configuration, and I'm not sure how you'd go about correcting for that.
Another thing to keep in mind is that wheelbase is a key factor in figuring out the angles too, and any generic D44 or D60 hi-steer arms that have offset tie rod holes are going to be designed for some arbitrary wheelbase. How far yours actually is from that will decide whether you're gonna be over- or under-steering through a curve.
